Discussion topic: Vibration noise from new sky qhd box
Message posted on 04 Apr 2023 01:23 PM
Old disc failed and received new box today but irritating vibration noise
Message posted on 04 Apr 2023 02:38 PM
Re: Vibration noise from new sky qhd box
@linda+tanner wrote:Old disc failed and received new box today but irritating vibration noise
Does the vibration stop if you press down on the top of the box? Sometimes if the box has been refurbished or poorly manufactured in the first place the screws holding the metal lid on can sometimes not be tightened enough. Similarly, the hard drive may not have been secured well enough.
If the vibration does stop with a bit of pressure then you could put a heavy-ish ornament on top of the box. As long as it doesn't completely cover the box it should be safe enough as heat needs to dissipate from the top.
Alternatively you can buy small rubber feet that you can stick to the bottom of the box - this can help with some types of vibration.
If this all sounds like too much faff, you can of course ring Sky and ask for another Q box. They shouldn't really vibrate at all.
Message posted on 03 Apr 2024 10:46 AM
i rejoined sky in jan 2024 and my sky q box vibrates unless i place an object on top of it.
old sky q box was much queiter, perhaps i have refurbished box who knows.
rubik cube works fine.
