Discussion topic: Very slow, unable to record or play recordings, films very slow to load, possible hard drive issue ?
This message was authored by: Katrina991
Very slow, unable to record or play recordings, films very slow to load, possible hard drive issue ? There is plenty of space, recordings are not full
Re: Very slow, unable to record or play recordings, films very slow to load, possible hard drive iss
@Katrina991
What makes you think it's a hard drive problem? Any error messages appearing? What have you tried already?
Avatar for Katrina991
Error msg on catch-up unable to connect, can watch BBC, etc ok, films very slow, won't play recordings, have restarted box several times, have had this issue for 3 days now.
Sounds like you may need to try a hard drive reset.
Would suggest you try resetting your hard drive, as described in this Sky Q article, link below, from Step2
Would recommend, restarting the box on Step 1 before following the reset on step2.
.Sky Help | Sky.com
As it mentions in the article. Be aware: resetting your hard drive will permanently delete all recordings, downloads, purchases downloaded to your Q box, reminders and series links.
have followed the instructions as per guidance.
tried step 1 several times but no impact.
have done the reset on step 2 so have wiped everything, but still unable to record so think its an issue with the box itself.....
This message was authored by: Invisiblename
The last link in the reset process is to order a replacement box.
I am just another Sky customer!
yep, thats my next option...
As mentioned above.
If you have tried resetting hard drive, as per the  Sky help article linked below and still having problems, you can via that link in the article request a replacement Sky Q box;
https://www.sky.com/help/articles/fix-recording-problems-on-sky-q-other-recordings-problems
Be aware, that when the courier delivers your new replacement Sky Q box and takes away your broken box, make sure you remove your current Sky viewing card from the broken box to use in your new replacement box.
