Discussion topic: Very slow download of uhd film on sky Q
Message posted on 16 Jan 2024 09:25 PM
Hi since December I cannot download and watch a UHD movie. I selected the movie then have to wait until it's downloaded 30 to 33% before it appears in recorded items to start watching. It did work fine until very recently. I have 200mbs broadband. And have tried resetting the box. Any other ideas ??
Message posted on 16 Jan 2024 09:33 PM
Re: Very slow download of uhd film on sky Q
Virgin broadband?
Have you got any mini boxes?
Message posted on 17 Jan 2024 04:50 PM
Yes one
Message posted on 17 Jan 2024 04:53 PM
Yes Virgin broadband and one mini box
Message posted on 17 Jan 2024 05:05 PM - last edited: 17 Jan 2024 05:05 PM
@Ryteee wrote:Yes Virgin broadband and one mini box
Just a theory / hunch but try powering the mini off completely and resetting the network on the Q and trying again. Leave the mini off.
Are the Q and router close enough for a decent wifi connection?
Message posted on 17 Jan 2024 08:28 PM
Yes within 6m I'm getting a 40- 60 mbs on the wifi that the sky box is on.
Everything worked as expected until recently. I was wondering if an update could have caused the issue.
I will give it a go then report back
thanks
Message posted on 17 Jan 2024 09:30 PM
No there haven't been any updates recently.
Message posted on 20 Jan 2024 04:30 PM
Hi so unplugged mini then reset network on Q as instructed. I did not reconnect the mini.
unfortunately it is the same as before.
Anymore thoughts??
thanks
Message posted on 20 Jan 2024 05:19 PM
And the mini is switched off at the wall?
Message posted on 20 Jan 2024 06:17 PM
Yes box was unplugged
Message posted on 20 Jan 2024 06:45 PM
Hmm
Just to check the router-internet connection I would test a direct ethernet connection. If that works well then maybe there is some conflicting wifi channel interference. You can sniff out wifi networks and see their strength and channels in use using Airport Utility on an iphone. Android will have similar.
Message posted on 20 Jan 2024 07:15 PM
I'm getting 40-60mbps on the wifi the Q is connected to. The odd thing about the problem is that the movie is not playable until it's over 30% downloaded which seems to take over an hour. Before this issue the movie would play at 2or3 %.
Message posted on 23 Jan 2024 06:28 PM
I have noticed that when I try to download UHD the mini is disconnected from the Q and can only be reconnected by doing a full reset.
Message posted on 23 Jan 2024 06:35 PM - last edited: 23 Jan 2024 06:37 PM
@Ryteee wrote:I'm getting 40-60mbps on the wifi the Q is connected to. The odd thing about the problem is that the movie is not playable until it's over 30% downloaded which seems to take over an hour. Before this issue the movie would play at 2or3 %.
Yes that's because it estimates how much it needs to buffer now so that once you start watching it won't have to pause mid-movie. The slower the download is, the bigger the percentage downloaded before it will say it's ready to start playing.
Have you tried testing a direct connection or scanning for interfering wifi networks as per above?
The mini disconnect is weird but maybe another symptom of whatever the underlying problem is.
Message posted on 23 Jan 2024 07:27 PM - last edited: 23 Jan 2024 07:28 PM
Theres another thread about this. I have a 900/900 fibre connection. Im attempting to download a UHD movie just now. Its downloading between 5-10 Mb/s. Such a bad experience. Its does vary. Maybe depending on time of day. Ive had 80 -100 Mb/s just a week ago. Must be Sky skimping on their servers.
