Discussion topic: Upstairs tv: after switching on, image appears less than a quarter size. On resizing the channel cha
Message posted on 29 Oct 2024 04:35 PM
Need help with Sky Q on our upstairs tv. Switching on there is a small size image. After resizing the channel changer does not work.
Message posted on 29 Oct 2024 04:39 PM
Re: Upstairs tv: after switching on, image appears less than a quarter size. On resizing the channel
Hi @Stuart75
Reboot the mini as above.
