Discussion topic: Upstairs looses connection when PS4 is on downstairs
Message posted on 22 Oct 2023 08:59 PM
Hi,
I have never had any issues before until the last week or so, whenever my kid turns her PS4 on downstairs my sky mini box upstairs immediately looses connection.
Can anyone think what could be causing this please.
Thanks,
Message posted on 22 Oct 2023 09:09 PM
Re: Upstairs looses connection when PS4 is on downstairs
5GHz ch 36 interference?
Message posted on 23 Oct 2023 06:50 PM
Do you have any ideas as to how i can fix this please.
Message posted on 23 Oct 2023 06:53 PM
Hi @Heidi4
Try the following. No guarantees
Reboot the mini as above.
If the mini still drops out try a Network Reset on the mini.
