Discussion topic: Upgraded to sky cinema but says I need to upgrade my subscription
Message posted on 17 Nov 2025 01:26 PM
Upgraded to sky cinema this morning but when we try to play a film it says I need to upgrade my subscription. We have tried it on all formats and it says the same. It works on sky go just not on the sky q box. I have unplugged the box multiple times anything else I can try before calling sky?
thanks in advance
Message posted on 17 Nov 2025 05:27 PM
Re: Upgraded to sky cinema but says I need to upgrade my subscription
thanks in advance
@DaniK1 You could try refreshing your viewing card by pressing home > settings > system info > viewing card number > setup > viewing card setup press select to trigger a callback don't worry nothing to do with your phone its only Sky's terminology this will be done over the internet
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
