Discussion topic: Upgrade to SkyQ from a HD+ Box and a Sky Box
This message was authored by: Fanbase
Hi.  I have had a letter from Sky to upgrade for free to Sky Q.  I have two Boxes, a Sky+HD in the main living area and a normal Sky Box in a bedroom.  With Sky Q can I upgrade so that I still have Sky in two rooms and would that cost a lot as well? Thank you
Re: Upgrade to SkyQ from a HD+ Box and a Sky Box
hi @Fanbase
With SKy Q there are mini boxes for secondary boxes - you can't have 2 main boxes.
To use a mini box you need the multiscreen add on - I am not too sure how the multiroom add on compares cost wise to the old multiroom
you may benefit from reading some notes I have put together for people thinking of miving from SKY HD to SKY Q
SKY HD to SKY Q
Any other questions feel free to ask
@Fanbase I believe the standard free upgrade path from Sky+ includes a Mini box and Multiscreen (Whole Home) subscription, but do check with Sky.
Avatar for Fanbase
Hi.  Thank you all for your help.  I appreciate it.
This message was authored by: bob1234
@FanbaseCheck with Sky to see exactly what they are giving some people have got the non UHD 1TB box, fine if you don't care about UHD.
Also, as mentioned in my linked notes,  the non UHD boxes only support 1 active mini
Avatar for Fanbase
Thanks for that will check.
