92
This discussion topic has been answered Discussion topic: Unwanted sign language in recordings downloaded
This message was authored by: Daviddddddddddd
Re: Unwanted sign language in recordings downloaded
Thanks Baldrick, Unfortunately and maybe we haven't all explained this clearly enough; the BBC supply programs with and without BSL. As you say, this is built in to a broadcast item, or not. Unfortunately this is only a theory, often the BBC only supply with BSL or only supply without or sometimes a series is supplied to Sky as a mix, some with and some without. For example, search Hotel Megabuild, three episodes, the first is without BSL, episodes 2 and 3 are with BSL.
What did Viewer Relations say?
They said it's nothing to do with Sky, BBC supply what they supply and Sky post it up for us to watch.
They're correct, I'm afraid. You could take it up with the BBC?
The BBC like all civil services are paid at the beginning of the year, rather than subscription so are answerable to no one. I wouldn't waste my time.
This message was authored by: Wendyl
Thank you lol I've been watching The Tourist season 2, back to back hit episode 5 and the guy signing appeared taking up half the screen. The rest of the episodes were fine buy this one was unwatchable, I gave up halfway thru. I'll try find it on I player then. I thought I'd somehow altered my Q settings and I couldn't find an answer online till I saw your comment. Much appreciated
This message was authored by: pdrum
It's not just the BBC, I have the same thing for a Chanel 4 recording of Grand Designs. Presume the same applies to this.
This message was authored by: Berkshire45
I have the same problem with a BBC program, I cannot seem to record it on my Sky box without the sign language person.  However I logged into iPlayer and it worked fine.  So not sure why it records it with the signer.
That would be because the version of the programme you recorded included BSL (typically an early morning broadcast). The answer is to select a different version to record.
This message was authored by: RachelLightfoot
I wathced an episode with no signing, but Sky then queued the next episodes with signing.  Why isn't the next episode without signing like the first?  This happen a lot on Sky Q and shouldn't be something the customer should have to put up with.  Not only is it extremely distratacting,  taking up a disproportionate amount of real estate,, the actual programme screen area has shrunk considerably.  Sort this out Sky.
This message was authored by: matt30uk
Find it incredibly annoying, trying to watch a number of  bbc series, watch 1 episode then download the rest and automatically get the sign language version seems ridiculous really.
@matt30uk you need to contact viewer relations at viewerR@sky.com as the BBC supply the assets so it may not be Skys fault and you may have to contact the BBC
This message was authored by: iiibizbysa
It sounds really frustrating for viewers who are dealing with unwanted sign language in their recordings. While it’s important to have accessibility options, the different versions can be annoying. It would be great if Sky could make it easier for people to choose their preferred version. Contacting viewer relations might also help find better solutions!
This message was authored by: rtb
No SL flag on my recordings, don't know until I play, crazy.
This message was authored by: Pete17
No. Not helpful. Still in a position where I download BBC iplayer recordings and get a signed version with no option for an UNsigned verson. Very frustrating as not only does the sign guy (who I'm sure is doing an amazing job for the audibly impaired) takes up a 3rd of the screen but the actual picture is in a small screen itself. WHY WHY WHY is there no option to select or not select this???????????(yes, I really did type 10 ?marks, that's how frustrated I am!)
Answered - Go to Answer
