Discussion topic: Unusual Sky page appears and jams.
Message posted on 05 Oct 2024 10:09 AM
Either in start up or when pausing a programme a summary Sky page appears and the tv is jammed on this. It won't even turn off. Can anyone help?
Message posted on 05 Oct 2024 10:13 AM
Re: Unusual Sky page appears and jams.
Hi @nic46 Is there any chance of an image? (See camera icon above).
Message posted on 05 Oct 2024 10:18 AM
Hi @nic46
Reset your Q box remote by pressing and holding 7 & 9 together on the remote until it’s led flashes four times.
This will set it to infrared which will work all Q boxes. However the remote must be pointed directly at the Q box.
Switch your Q box back on and you then you should be able to get past the setup issues.
Once you get the Q box working make sure that you are pointing your remote at the Q box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
Message posted on 05 Oct 2024 10:24 AM
sorry MightQuinn where is the camera icon? I'm tech incapable!
Message posted on 05 Oct 2024 10:35 AM - last edited: 05 Oct 2024 10:35 AM
Hi @nic46
You cannot upload images until you reach Level 1
Edit
You have just reached this level so it's OK now
Message posted on 05 Oct 2024 10:36 AM
Pressed 7&9 but no red dot visible. The box turned off and now won't start again. This has been an ongoing problem where it takes several goes to get the box to start up. Right now it won't at all.
Message posted on 05 Oct 2024 10:40 AM
Message posted on 05 Oct 2024 10:41 AM
Hi @nic46 Does the remote led show when you press the "?" button? Have you tried new batteries?
Message posted on 05 Oct 2024 11:10 AM
Thank you for helping me. I don't seem able to have any success. Do you know how I get Sky to step in?
Message posted on 05 Oct 2024 11:20 AM
I put new batteries in and still no LED when I press 7&9. Where is the ? Symbol please. Thx
Message posted on 05 Oct 2024 11:22 AM
Ok it's started up again on the jammed page. Can you help me take a photo of it to send you?
