Discussion topic: Unplugged sky to move and wben turned back on its not working
Message posted on 06 Mar 2024 01:55 PM
Unplugged to move and when turned back kn it doesn't work
Message posted on 06 Mar 2024 01:57 PM
Re: Unplugged sky to move and wben turned back on its not working
To move within the house or moved house?
Message posted on 06 Mar 2024 02:00 PM
Within the house ?
Message posted on 06 Mar 2024 02:01 PM
Any error message on screen or aren't you getting that far?
Message posted on 06 Mar 2024 02:03 PM - last edited: 06 Mar 2024 02:04 PM
hi @Frank47
if the problem is a No Satellite Signal then may I suggest you undo the Satellite Cables and, although a bit difficult to check, check that there are no fine strands of the out sheathing copper touching the central core wire.
Also double check that the central core wire has not broken short
then try re-seating the cables and powering back on
Message posted on 06 Mar 2024 02:15 PM - last edited: 06 Mar 2024 02:30 PM
Maybe note that in a property previously cabled for Sky+ HD Multiroom, relocating a main Q box to a different room typically doesn't work because only one cable pair remains connected at the dish end once the LNB is changed during initial Q installation: this would generate a 'no satellite signal' message on-screen.
