Discussion topic: Unplugged sky to move and wben turned back on its not working
This message was authored by: Frank47
Unplugged to move and when turned back kn it doesn't work
Re: Unplugged sky to move and wben turned back on its not working
@Frank47
To move within the house or moved house?
▪️I AM NOT A SKY EMPLOYEE ▪️
Avatar for Frank47
Level 0 icon
Within the house ?
@Frank47
Any error message on screen or aren't you getting that far?
hi @Frank47
if the problem is a No Satellite Signal then may I suggest you undo the Satellite Cables and, although a bit difficult to check,  check that there are no fine strands of the out sheathing copper touching the central core wire.
Also double check that the central core wire has not broken short
then try re-seating the cables and powering back on
@Frank47
Maybe note that in a property previously cabled for Sky+ HD Multiroom, relocating a main Q box to a different room typically doesn't work because only one cable pair remains connected at the dish end once the LNB is changed during initial Q installation: this would generate a 'no satellite signal' message on-screen.
