Discussion topic: Unable to turn Sky Qbox on with remote
This message was authored by: B_1H
As the remote would not turn SkyQ box on we put new batteries in but it still won't turn SkyQbox on so have been unable to watch anything. We tried turning off and unplugging at the socket still without success. Could we need a new remote?
Re: Unable to turn Sky Qbox on with remote
Hi @B_1H   I would try resetting your reboot by holding down the 7 & 9 keys until the LED flashes four times. It will now be unpaired and in IR mode, so line of sight required. Hold down 1 & 3 to re-pair.
Resetting your remote
Hi @B_1H
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
This message was authored by: Sue257
I need an engineer or new box
@Sue257 what problem are you having perhaps we can help you
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
