Discussion topic: Unable to recieve sky q on my bedroom ty ive tried to switch off and reboot box but still not workin
This message was authored by: Djbooks
Whst info fo you meed
Avatar for Djbooks
Re: Unable to recieve sky q on my bedroom ty ive tried to switch off and reboot box but still not wo
What info do you need
Hi @Djbooks
Reboot the mini as above.
Avatar for Djbooks
I have tried all this and still mot working when the engineer set up my sky q it has been working well for several months but has stopped wirking now can an emgineer visit to sort it out please
Hi @Djbooks
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Hi @Djbooks
I have escalated your post to Sky.
You may receive an email or a private message inviting you to have a private conversation on the Community with a Sky Expert.
Look out for a chat bubble at the bottom of your screen inviting you to a chat
The link below explains how the escalation process works
This message was authored by: Greenfingers001
Thanks for escalating this. We’ve sent @Djbooks an invite to chat.
