Discussion topic: Unable to play recordings on mini box from F1 channel
This message was authored by: GRANTORINO-1
Unable to watch recording in mini box from Sky Sports F1 that ha e been recorded on main box
Re: Unable to play recordings on mini box from F1 channel
What kind of message are you getting, when trying to play them?
Also, if the recordings on your main box are recorded in uhd, they will not play on your mini, as the mini can only play hd/sd recordings.
@GRANTORINO-1 are you trying to watch somewthing that was recorded in UHD on the main box as if so the mini boxes cannot play UHD recordings.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
@GRANTORINO-1
As indicated above, a Mini box outputs HD at most, and a main Q box cannot take a UHD recording and reduce it to HD to pass to a Mini for playback as that would require rather more processing power than its CPU possesses.  Given Sky Sports F1 is one of the few channels broadcast in UHD, that's the most likely explanation: for Mini box playback you'd want to be recording the HD broadcast channel too.
