Discussion topic: Unable to pair Sky Q remote to new Panasonic TV, the model we have is not on the Sky list
This message was authored by: Redstrpesleslie
Tried the 7&9 buttons followed by the 1&3 buttons on Sky Q remote to pair the latter to new TV but message came up as unsuccessful!, Sky list has a TX-43MX600B on their list but not the TX-43MX800B model that we have, has anyone encountered same problem?, is it worth trying to pair the remote to the 600B model%.
Re: Unable to pair Sky Q remote to new Panasonic TV, the model we have is not on the Sky list
Hi @Redstrpesleslie
I'd suspect that the models would have the same setting.
Also try the remote setup in Home - Settings - Setup - Remote Control.
Avatar for Redstrpesleslie
Hi@oldfella, thanks for reply, tried pairing remote using method you mentioned but it was unsuccessful primarily I believe because the TV model we have is not on the Sky list!, annoying
hi @Redstrpesleslie
Just try using the 'Find it' for me option - my 42MZ980 & GZ980 both work with the first code suggested for Panasonic
Hi @Redstrpesleslie
Most models of the same brand will normally have the same remote coding.
With the Q box on with green led try completly resetting your Bluetooth remote again.
Hi @nigea99, thanks for the reply, I'll give that option a try tomorrow but when trying to pair the remote today there were 25 options to try and none worked!!
hi @Redstrpesleslie
I would be very surprised if the 1st one doesn't work - to my knowledge Panasonic rarely changes its codes & the older TV remotes I have had over the last several years have worked my newer TVs - as I mention my MZ (last years OLED model - the same model  year as your MX LED) works with the same codes as my older GZ TV.
Hi@oldfella, thanks once again, I tried that precise method 3 times today to no avail so will try the find it method tomorrow and see if that works
Hi@nigea99, thanks again, will have another try of the option you advise, fingers crossed I get some success
This message was authored by: Mister_Dalek
@Redstrpesleslie
One other thing to try is choose Vestel as the manufacturer instead of Panasonic.
Vestel make some of the cheaper Panasonic LCD models for the European market.
Hi Mister-Dalek, many thanks will have a try with that option too
This message was authored by: GinaG63
I had the same problem went to inputs and it was in there
This message was authored by: Deeaf
I was experiencing the same issue on my new Panasonic model TX-55MZ800B and I tried the suggestion of using Vestel as the model of the TV instead of Panasonic and it worked straight away.  Thanks for providing thge suggestion!
This message was authored by: Larky1
Thanks so much. Ive been having same issue with my new panasonic not being  listed. Just tried vestel and 2nd code in worked:lia_thumbs-up::lia_thumbs-up::lia_thumbs-up::lia_thumbs-up::lia_thumbs-up::lia_thumbs-up:
This message was authored by: ArchieB1
Having the same problem with a new Panasonic and Sky Stream remote.
Vestel doesn't come up as an option. :lia_worried-face:
