Discussion topic: Unable to obtain IP address with Ethernet connection
Message posted on 24 Feb 2024 12:28 PM
We have been using Sky Q with Ethernet connection successfully for 2 years - we have the mini boxes hard wired as well. The connection to the main box has now gone down and will not reconnect. When I select on Q box to connect via Ethernet it is saying it cannot obtain an IP address. The Wi-Fi is disabled in the Engineer Settings) We have rebooted router (everything else in the house is working fine on the internet) I have reset the Q box, switched everything off and back on......nothing is working and I am out of ideas!
Message posted on 24 Feb 2024 12:29 PM
Re: Unable to obtain IP address with Ethernet connection
Weird. Have you double checked wifi is definitely off? Has a habit of zombiefying itself.
what happens if you try to give it a manual IP address?
Message posted on 24 Feb 2024 12:31 PM
Wi-Fi is definitely off (checking everytime to be certain!)
Message posted on 14 Oct 2024 09:39 PM
This has started happening for me this week after many months of working without issue.
Did you find a solution?
