Discussion topic: Unable to get into Paramount + after doing an 001 reset on Sky Q
This message was authored by: Janj
I'm Unable to get into Paramount + after doing an 001 reset on Sky  as the screen kept going black.
I've also done an update as per previous advice.
Avatar for Janj
Re: Unable to get into Paramount + after doing an 001 reset on Sky Q
When I try to go in to Paramount it says "Get paramount" then you have paramount press "open", which I do, then it sends me back to "Get Paramount".
