Discussion topic: Unable to connect to my Wi-Fi
This message was authored by: DaveF64
I noticed this morning that my Sky Q was not connected to the internet, this has been connected previously via Wi-Fi and until now i never noticed a problem. I have tried to reset it but to no avail. anyone have any suggestions
Thnaks
Dave
Re: Unable to connect to my Wi-Fi
Thnaks
Dave
Hi @DaveF64 .
