Discussion topic: Unable to connect sky broadband to sky q box
Message posted on 12 May 2024 05:58 PM
Just received a new sky router. Followed set up instructions. Internet is connected to phone but sky q box is unable to connect. Message on screen says I may need a sky booster.
Message posted on 12 May 2024 07:17 PM
Re: Unable to connect sky broadband to sky q box
Hi @Ann100
On Sky broadband hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky router
On Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
Message posted on 19 Aug 2024 03:05 PM
Setting up new Sky Q box, unable to press WPS button on Sky broadband router because there is not one on the router, w
hat do I do now?
Message posted on 19 Aug 2024 03:09 PM
@langport wrote:Setting up new Sky Q box, unable to press WPS button on Sky broadband router because there is not one on the router, what do I do now?
I suspect there is a button - read https://helpforum.sky.com/t5/Broadband/Where-is-the-WPS-button-on-the-new-broadband-router/td-p/3773...
Message posted on 23 Aug 2024 12:34 PM
I have a similar but reverse problem, I reset the broadband box and since then SkyQ has not been able to connect to it and can't find it. What do I do?
