Discussion topic: Unable to connect sky Q box to the wifi
Message posted on 28 Jul 2024 11:34 AM
I am unable to connect my sky Q box to the wifi. It was connecged previosuly when the engineer came to install the fibre broadband box, but now will not connect despite resetting the skyQ box and the router
Message posted on 28 Jul 2024 12:04 PM
Re: Unable to connect sky Q box to the wifi
Hi @Hev1304
