Discussion topic: Unable to connect Skye box to router
This message was authored by: JackSophie
Followed instructions to connect SkyQ box to router and after resetting the router, it still won't work. We hold down WPS on the router and the skyQ box is not finding anything.
Re: Unable to connect Skye box to router
Hi @JackSophie
You can only use WPS if you have Sky Broadband.. Try the complete procedure again
