08 Feb 2024 10:49 AM
I am unable to connect my Sky Q multi room box to my new internet provider. It is failing to pair up with the main box. I had no problem connecting the main Sky Q box.
08 Feb 2024 11:17 AM
Hi @AS25
Reboot the mini as above.
