Discussion topic: UHD content saying press red button to upgrade
Message posted on 12 Nov 2024 10:23 AM
Hi I have sky cinema package and upgraded to uhd yesterday. If I try and select a uhd film in sky cinema it says press red button to upgrade. I have changed the preferences to download in uhd and changed visual setting to uhd 10 bit which has worked. How do I watch a film in uhd please?
Message posted on 12 Nov 2024 10:44 AM
Re: UHD content saying press red button to upgrade
@Gary+Richards wrote:Hi I have sky cinema package and upgraded to uhd yesterday. If I try and select a uhd film in sky cinema it says press red button to upgrade. I have changed the preferences to download in uhd and changed visual setting to uhd 10 bit which has worked. How do I watch a film in uhd please?
Try giving your Q box a reboot. Turn it off at the wall for a minute then power it back on. Sometimes a restart can force it to read your viewing card again and sync up your account details. If it doesn't work then you may need to ring Sky for further troubleshooting.
Message posted on 12 Nov 2024 11:23 AM
Hi thanks tried refreshing viewing card but still the same. If I go to sky cinema uhd and click on upgrade box it comes up saying already subscribed but still asking for red button if I try to view anything. If I press red button nothing happens and can't watch uhd content.
Message posted on 12 Nov 2024 12:06 PM - last edited: 12 Nov 2024 12:07 PM
Check in your Q box Home menu - My Sky.
Make sure the UHD add on is shown on your account.
If it is then,
