Discussion topic: U and W downloads sky q
Message posted on 05 Mar 2025 05:45 PM
Hi
Why cant I download any u and w shows? Hd/sd at all but it's meant to be a free to air channel?
Message posted on 05 Mar 2025 05:57 PM
Re: U and W downloads sky q
@Cre wrote:
Hi
hi @Cre
U&W is Free To air in SD but not HD
So if you do not have the HD add on you will need to change your dwonload preference
So as the default download quality is set to HD (high Definition) not SD then when you try to download and watch you are prompted to upgrade if you don;t have it (i.e. take out the HD subscription)
You, probably, just need to change your download preference to SD
Main Menu -> Settings -> Setup -> Preferences
(Please note this setting can only be set on the Main box)
Message posted on 05 Mar 2025 09:45 PM
I'm unable to download in either HD or SD I figured it was to do with not having a HD pack. However I'm unable to download in SD either so unfortunately this doesn't resolve the issue thanks thou!
Message posted on 06 Mar 2025 04:24 PM
@Cre what happens when you try ? do you get any error messages
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 06 Mar 2025 05:10 PM
hi @Cre
Did you change to SD by changing the setting I mentioned or did you just try 'other formats'
I ask because I think selecting SD from 'Other formats' can be erratic
Message posted on 06 Mar 2025 10:35 PM
Tried it both ways.no change still same message
i keep getting the message you need a subscription to download this show please upgrade message
Message posted on 07 Mar 2025 07:06 AM
Message posted on 07 Mar 2025 11:05 AM
I have the essentials pack but u and w are free to air channels so shouldn't be affected by not having the boxsets
Message posted on 07 Mar 2025 11:19 AM - last edited: 07 Mar 2025 11:50 AM
hi @Cre
I do not know if there are any quirks with U&W (or other U&xxxx FTA channels) with the Essentials subscription but I have escalated your post to a SKY support team, who, hopefully, will be in touch.
Please see this link re the escalation and what you might see:
If you are using Safari I believe you must make sure that 'Hide IP address' is not checked in settings to be able to see it - if you have difficulty finding that setting then may be try accessing here with another browser
Message posted on 07 Mar 2025 11:26 AM
Thanks for escalating this. We’ve sent @Cre an invite to chat.
