Discussion topic: Tvs working but SKY not showing picture or sound
This message was authored by: BUZZJAY
Sky is connected TV is fine. Sky shows menus and guides etc but no sound or pictures. We recently changed to full fibre
Re: Tvs working but SKY not showing picture or sound
Hi @BUZZJAY
Have you tried rebooting your Q box?
Failing this reset your Broadband connection.
Not if you have a Sky Max router follow instructions below for 3rd party router.
@BUZZJAY you've posted the same thing on the Stream forum. Which do you have?
