Discussion topic: Tv won’t turn on whirring noise from sky box
Message posted on 28 Oct 2025 08:58 PM
How can I get my tv to turn on
Message posted on 28 Oct 2025 09:02 PM
Re: Tv won’t turn on whirring noise from sky box
@Rupert7 Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 28 Oct 2025 09:03 PM
Hi @Rupert7
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
