Discussion topic: Tv not working after update to wi fi
Message posted on 09 Oct 2023 04:05 PM
Update to wi fi means TV is not working now
Message posted on 09 Oct 2023 04:08 PM
Re: Tv not working after update to wi fi
@Giddsey Can you explain in more details?
Live TV should still work on Sky Q as this is delivered over satellite and is not relient on broadband at all.
Have you been through these steps for the wifi issue? https://www.sky.com/help/home/sky-tv/sky-tv-q/fixing-sky-q/fixing-connectivity/fix-connection-proble...
Message posted on 09 Oct 2023 05:18 PM
Hi @Giddsey
Assume you are referring to your Main Q box?
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
