Discussion topic: Tv not saying hdmi only no signal
This message was authored by Skynonworking This message was authored by: Skynonworking
When I turn on my TV  with sky it usually says hdmi2 but its not showing that just no signal when I press sky remote to get channels up nothing happens when I press house button and box has only I light at the end card side.hope u can help new battles  in remote
This message was authored by Mark39 This message was authored by: Mark39
Re: Tv not saying hdmi only no signal
If the tv message is 'no signal' you're probably tuned to the wrong HDMI I out. Makesure the power light on your Sky box is green. Look for an AV button on your TV remote and use it to cycle through HDMI inputs until you get to HDMI2.
Hi @Skynonworking
If the light on the front right of the Q box is amber instead of green
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
If the light is already green
First make sure that the TV is switched on and is switched to the HDMI input to which the Q box is connected.
Then with the Q box switched on with green led illuminated
Press
Home 1 0 8 0 Home
on the Q box remote control.
This will change the Q box to standard resolution which will work for all TV’s.
