Discussion topic: Tv channel guide not showing some channels
This message was authored by: Ross62
TV not showing scheduled programmes on some channels and unable to see scheduled programmes
Re: Tv channel guide not showing some channels
@Ross62
Usually rectified by rebooting the box. Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
