Discussion topic: Trying to pair replacement remote with Sky Q and Samsung TV, I can turn on the box but not the T.V.
Message posted on 17 Feb 2025 09:56 PM
Hello, I'm trying to pair a replacement remote with the SKY Q box and Samsung T.V. I can turn the box on but not the T.V. I've tried 7 & 9, and 1 & 3, I've also tried the T.V remote but it won't switch on. Can someone advise me please?
Message posted on 17 Feb 2025 10:00 PM
Re: Trying to pair replacement remote with Sky Q and Samsung TV, I can turn on the box but not the T
Hi @Bowiefan
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to pair to TV
Message posted on 17 Feb 2025 10:02 PM
Hi Oldfella, Thank you for your response, I have tried those code pairings a number of times, the box turns on but not the T.V so there's no way to see let alone follow the onscreen instructions.
Message posted on 17 Feb 2025 10:06 PM
May I suggest you use the TV's own remote (or physical buttons on the TV) until you have managed to pair the SKY remote
