Discussion topic: Trying to istall Sky Q mini... Locked up with error MR104
Message posted on 21 Sep 2024 11:21 AM
The boxes are in the same room so no communication problems. All was gioing well until the on screen instructions told me to press the button on the main box to establish the IP address....
This was done but it failed with error MR104.
I am now locked up and can't restar anything
RM
Message posted on 21 Sep 2024 11:23 AM
Re: Trying to istall Sky Q mini... Locked up with error MR104
RM
Hi @RMoger
Reboot the mini as above.
Message posted on 21 Sep 2024 11:50 AM
I am on sky broadband, but there is no router, but I will try the process you describe... I have already done resets, but not in that exact sequence...
RM
Message posted on 21 Sep 2024 12:03 PM
Message posted on 21 Sep 2024 12:09 PM
There is always a router
Message posted on 21 Sep 2024 12:13 PM
OK thanks... Up and working now.. Looks like it was the sky network response that was missing. The two resets did the trick..,,,
Thanks RM
Message posted on 21 Sep 2024 12:23 PM
There is no seperate router. The main Q box is fed directly from the primary entry wall socket, which must fulfill that function. Input is via a short 100m of copper telephone wire to a BT fibre. connection.
