Discussion topic: Toshiba TV can't connect to Sky Broadband
Message posted on 23 May 2023 10:41 PM
When I try connecting my Sky Q box to WiFi:
1) it won't connect when searching for Sky Broadband
2) it won't connect when searching for non sky broadband. It finds the sky broadband but then it won't accept the password
3) even the ethernet cable option doesn't bring any success
Any suggestions?
Message posted on 24 May 2023 11:06 AM
Re: Toshiba TV can't connect to Sky Broadband
Message posted on 26 May 2023 10:24 AM
We are still looking to help you. If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
Lisa - Sky Tech Team Expert
Message posted on 26 May 2023 10:26 AM
Yes my TV is working fine as it was able to pick up my mobile phone as a hotspot using the sky broadband WiFi. However getting the TV to connect direct to the Sky Broadband WiFi it won't pick it up.
Message posted on 26 May 2023 11:40 AM
@AlanOrkney wrote:Yes my TV is working fine as it was able to pick up my mobile phone as a hotspot using the sky broadband WiFi. However getting the TV to connect direct to the Sky Broadband WiFi it won't pick it up.
I think you missed the point @Lisa-P1987 was making in that you failed to pick up the chat offer within the alloted 48hr period. Consequently your issue will require re-escalating to get a Sky tech to chat with you.
Message posted on 26 May 2023 11:42 AM
Yes the case needs escalating
Message posted on 26 May 2023 11:46 AM
@AlanOrkney wrote:Yes the case needs escalating
It needs someone with that authority to do so. Once it has been opened again, you'll need to keep your eyes open on this forum for the blue chat bubble to open up - you have 48hrs from then to respond.
Message posted on 26 May 2023 01:49 PM
@AlanOrkneyI am confused.
Is your Q box working and is it your TV that will not connect independently to your home WiFi. If you have used Ethernet to connect your router to the TV and it does not work it looks like a problem with your TV.
Message posted on 26 May 2023 01:53 PM
TV is working as it connects to my mobile hotspot.
Broadband is working as mobile connects to WiFi.
However when try connect TV to broadband then it a) can't find sky broadband, then b) when searching for other WiFi it sees the sky broadband but then rejects the password (even though my phone connects to sky broadband WiFi). TV too far for a physical ethernet cable connection
Message posted on 26 May 2023 04:34 PM
@AlanOrkney wrote:TV is working as it connects to my mobile hotspot.
You keep mentioning that you are trying to connect your TV to the internet. Do you actually mean that you are trying to connect your Sky Q Box to the internet?
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
