7
This discussion topic has been answered Discussion topic: Tool to undo the Sky Q box connectors
This message was authored by: elderwandninja
Where can I get something to loosen the connectors without damaging them? the silver nuts that fasten the Sky Q cables to the back of the Sky Q box
This message was authored by: Godfrey Answer
Re: Tool to undo the Sky Q box connectors
@elderwandninja   An example of a suitable spanner that slips around the coaxial cable, found after searching for;  F Connector Screw Type Coax Plug Long Arm Fastener Screwdriver/Spanner
The top of the handle has a screw thread which is intended to hopefully help restore the internal thread of the F connector nut, if it had inadvertently been cross threaded.
Godfrey.
NB my previous post which included a direct link to this example of a typical suitable device disappeared after a few minutes and will probably re-appear mid morning on Monday after being reviewed!
They should only be handtight?
Avatar for elderwandninja
Level 4 icon
Yes I know but I'm asking because it's jammed
One came with my Virgin Media modem... But you can buy them:
Search for 'F connector spanner' - they're on eBay for a few quid, e.g. https://www.ebay.co.uk/itm/314081254442
@elderwandninja  This is a typical example of a suitable spanner.
Typical example of F connector spanner
Godfrey.
7/16" wrench. Drop of pentrating oil might help.
Godfrey.
Level 4 icon
Thank you , that's fantastic 👍
