3
This discussion topic has been answered Discussion topic: To watch netflix on other devices away from home do i sign into sky first?
This message was authored by: Sarahd2
Moving over to sky stream with netflix included. Just wondering if getting onto netflix while on my mobile or laptop involves going through sky first or just logging into netflix
This message was authored by: nigea99 Answer
Re: To watch netflix on other devices away from home do i sign into sky first?
hi @Sarahd2
You can log directly into a Netflix app on any device - you are just limited to the number of concurrent devices in use.
you also need to be aware that Netflix also now monitor for use away from the 'household'
hi @Sarahd2
This message was authored by: Rkd419
When I log into Netflix account on my iPad do I use any log in?
hi @Rkd419
You use the same credentials as you would/did to login to the app on SKY Q - note these are the email ^& password  you used for Netflix & are not SKY credentials
