Discussion topic: To picture keeps freezing and disconnecting from q box
This message was authored by: Davi4
My sky multi room box keeps freezing picture and I have to keep connecting to wi fi
Re: To picture keeps freezing and disconnecting from q box
Hi @Davi4
Reboot the mini as above.
