Discussion topic: Tnt says no satellite signal
Message posted on 17 Aug 2024 08:41 AM
Only my tnt says no satellite signal. It has been like this for the past week, I've restarted the system but still not working
Message posted on 17 Aug 2024 09:12 AM
Re: Tnt says no satellite signal
@JackDickie
If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
