Discussion topic: Threatening messages about returning equipment I don't need to
Message posted on 17 Nov 2025 07:17 PM
I have extending my sky contract but keep getting messages about returning equipment or I will be billed. No contact number supplied to explain
Message posted on 17 Nov 2025 07:30 PM
Re: Threatening messages about returning equipment I don't need to
You do need to contact Sky.
The current methods for contacting Sky are below and depending on the reason for making contact some methods will be more appropriate than others……
🟫 📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline if you have Sky Broadband. The forum doesn’t allow the display of other numbers. Other official numbers to Sky from the UK are 03 numbers which are normally inclusive from non Sky phones.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
🟫 online help via this link
https://www.sky.com/help
🟫Sky Assistant 💬 should also be available via
🟫Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
🟩Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
