Discussion topic: This channel is currently affected by a problem with your satellite signal
Message posted on 26 Apr 2025 02:23 PM
A selective number of channels such as TNT, some foreign news channels etc are not available with the following error message "This channel is currently affected by a problem with your satellite signal". However, Sky channels such as news, sports, Atlantic etc and terrestrial channels such as bbc etc are available, I've reset router, main Sky box and Sky q boxes and still can't get the affected channels back, any idea greatly appreciated.
Message posted on 26 Apr 2025 02:26 PM
Re: This channel is currently affected by a problem with your satellite signal
Message posted on 26 Apr 2025 02:45 PM
@Paulie9
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
Message posted on 26 Apr 2025 03:18 PM
@Paulie9 its also mindful that its that time of year when trees and plants etc are growing and gaining leaves so it may be that some new growth is partially obscuring your dish could have a quick look to see if there appears to be any growth in the line of sight of the dish
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
