Discussion topic: There is an orange light on Sky Q box and it won’t switch on
This message was authored by: Barry1275
Re: There is an orange light on Sky Q box and it won’t switch on
@Barry1275  Try unplugging the box and follow these steps https://www.sky.com/help/articles/sky-q-box-wont-turn-on-t2
Hi @Barry1275
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Avatar for Barry1275
Thanks tried the software update three times but still can't get it to boot up. It's stuck on standby
