Discussion topic: There is a technical fault with this channel
This message was authored by: Paisa113
There is a technical fault with all my channels, my sky Q mini box has no signal but is displaying this message. My main box
is working fine so it's not a main box issue.
also I can see all the headers and menus, even see all my recordings headers but the moment I choose something to watch it will either have the blue screen with the message "there's is a technical problem with this channel" or it will just be a black screen.
Re: There is a technical fault with this channel
Hi @Paisa113 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, then do the same with any mini boxes?
