Discussion topic: There is a technical fault so no sky tv for 2 days.
This message was authored by: DameDeels
Sky q mini hasn't worked for the past 2 days. Just a constant blue screen with "there is a technical fault with this channel. Please try again later." Written
Seems to be all channels including audio. Am connected to network hub is all fine just getting no TV. Any ideas
Re: There is a technical fault so no sky tv for 2 days.
What are your Signal Strengths/Qualities? Take a look at the link below:
See question Q11 in my Sky Plus F⋅A⋅Q
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Avatar for DameDeels
Which button is the services button?
You've posted in the Sky+ forum but if you don't know where the Services button is then it sounds like you have posted to the wrong forum 😞
Sounds about right. Thanks for trying Annie 😊
Which Sky System do you have?
1. Sky Plus (Sky Plus Forum)
2. Sky Q (Sky Q Forum)
3. Sky Glass/Sky Streaming Puck (Sky Glass Forum)
I've a sky q mini. The main box is being odd intermittently but the mini is just not doing anything at all.
Re: Theres a technical fault with this channel
Seems to be all channels including audio, but can connect to Netflix ans Spotify etc fine.
Am connected to network hub is all fine just getting no TV. Any ideas??
Hi @DameDeels
Work through the following link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
@DameDeels  Your post has been moved to the Sky Q forum as you have Sky Q. Your duplicate thread has been removed and the reply posted to that thread moved here.
