Discussion topic: The tv guide isn’t working it just says waiting for schedule and has been for 3 days now!
This message was authored by Debzyme This message was authored by: Debzyme
For three days all we can get is a message saying waiting for schedule and a spinner. We've tried turning the boxes off and on again tried re syncing it to the wifi but nothing is working. It is happening on the main box and the mini box
Re: The tv guide isn’t working it just says waiting for schedule and has been for 3 days now!
Hi @Debzyme
Try a Reset Settings in the main Q box hidden menu.
If the reset settings fixes the main Q box then try rebooting the mini again.
