Discussion topic: The sky dish was iinstallied pointing at a tree in wintertime. Now with leaves the signal is gone.
Message posted on 12 Jul 2024 11:58 AM
the enigeer said to cut the tree down. Is there a nother satellite?
Message posted on 12 Jul 2024 12:01 PM
Re: The sky dish was iinstallied pointing at a tree in wintertime. Now with leaves the signal is go
@moybank Sky UK use the orbital position at 28 East, the dish can't be pointed at another satellite as it wouldn't get any of your channels.
Unless you can find a suitable location for the dish or you can get the tree pruned you options are going to be limited, to Sky stream.
Message posted on 12 Jul 2024 12:36 PM - last edited: 12 Jul 2024 12:39 PM
There are actually three satellites in use by Sky UK (and Freesat) but as @GD1 indicates they are all in the same orbital location so that only one dish is necessary.
https://en.m.wikipedia.org/wiki/Astra_28.2E
Any television dish you may see oriented elsewhere is picking up European television in languages other than English.
