Discussion topic: The sky box on my bedroom isn't connecting to Internet and the message on screen to fix it has froze
Message posted on 11 Mar 2024 12:19 PM
The box in my bedroom isn't connecting to Internet and the message on screen to try and fix it has froze.
Message posted on 11 Mar 2024 12:25 PM
Re: The sky box on my bedroom isn't connecting to Internet and the message on screen to fix it has f
Hi @Sandy13
Reboot the mini as above.
