Discussion topic: The red light, which normally shows when recording, is on constant
This message was authored by: sdw101
The red light, which shows something is recording, is on constantly even when not recording
Re: The red light, which normally shows when recording, is on constant
@sdw101
Have you downloaded something and it's stuck?
Check Recordings > Manage > Downloading
Hi @sdw101
See if a Reboot clears it?
