Discussion topic: The new handset does not control the sky q box. volume or turn the tv off
This message was authored by: Tim19571
I reported that some of the functions on the sky Q handset was not working.  Sky sent me a new handset but this did not correct the fault.
The handset does not control the volume or turn off the TV.
Re: The new handset does not control the sky q box. volume or turn the tv off
Have you paired the remote handset with the television?
https://www.sky.com/help/articles/setting-up-q-remote
Neither of those is a Q box function.
Have you paired it and set it up for your particular brand of TV?
Hi @Tim19571
Try completly resetting your Bluetooth remote.
