Discussion topic: The minibox takes several seconds to respond to remote input.
This message was authored by: Ngp77
The last few weeks when watching recorded rugby it has taken a few seconds for the box to respond to inputs. Last night it was much worse e.g. up to 5 secs to respond. Then there was a blue screen message saying the minibox had lost connection.
Turning the box off at the mains allowed it to reconnect but then the lagging still happened intermittently.
The minibox is in a room directly above the main box which is hard wired into the router, which again is directly below the minibox.
WiFi signal is strong (+50mbps in the loft - which is a floor above and the other side of the house.
Re: The minibox takes several seconds to respond to remote input.
@Ngp77 Have you tried rebooting your main Q box ie
then rebooting your mini box as the mini box gets it's signal from the main box and unless you have your broadband with Sky then it doesn't use your wifi signal it uses a mesh created by the main box
