Discussion topic: The green light to come on on my skills skybox
This message was authored by: Welsholdfat
When I try to switch on my sky box, the orange light stays on all the time it doesn't change to green
Re: The green light to come on on my skills skybox
Hi @Welsholdfat
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
