Discussion topic: The future of Sky Q
Re: The future of Sky Q
Hi @Edward3345   Yes, it is a Sky Q Satellite box.
This message was authored by: Edward3345
Hi,
So how come I can get Sky on it without any dish...?
But there is.  Somewhere.
Hi @Edward3345   That is the reason why I have not replied to you. As far as I know, that is impossible. We need an image of the rear of your box, showing the connections.
hi @MightyQuinn
Whilst communal  feeds are usually used with apartment blocks, it is  quite possible (& in this case I am fairly certain) that @Edward3345  receives a Communal feed and this being the case may have no knoweldge of the location of a dish in the system which could be miles away.
@nigea99 wrote:
hi @MightyQuinn
Hi @nigea99   Yes, I was hoping that they would show us the communal feed connection.
Already said why I can't do that,I am Disabled....!!
@Edward3345 wrote:
Hi,
Please just accept that you have a satellite television box, it's working, therefore, somewhere at the other end of the cables that are plugged into it, is a satellite dish.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
The sky box is situated in a solid wood cabinet on a narrow shelf and I cannot access it on my own. I can't get to the back of the box,the sky engineer put it in and all the leads go through a small hole in the back of the cabinet.I watched him install it for me. There was a hdmi lead to the modem,a power lead to the mains and another lead to my TV on the wall above the cabinet.......that's all..
This message was authored by: Invisiblename
Then you will just have to accept what you have been told by others that there MUST be a Sky dish connected to your Sky Q box... that's the only way it can receive broadcasts.
I am just another Sky customer!
I presume you have seen my earlier posts regarding a communal feed
  • And as already stated,I do Not have any dish,there is no dish in the cul- de-sac where I live.I just have fibreber500 from sky to the house,the cable for this enters my home from a telegraph pole in the street. Also there's leads to other houses in the street from the same pole...???An engineer from sky fitted this putting a very small white box fastened to the outside brick wall of my house and then drilled a hole into my living room and then to my router via a small box he installed on my inside wall and a telephone cable as well to the router for my house phone....
@Edward3345  do not concern yourself.
As I have said, I am confident that you have what we call a communal feed.
These are not common outside of apartment blocks but sometimes are provided by indivual Fibre providers or on new build estates.
In these case, as I have said, there will be a dish but may even be many miles from you and thus you would not be aware of it
FIRS (Fibre Integrated Reception System)
I was trying to remember the full name - thanks!
