Discussion topic: The channels are changing on their own. Just randomly ending up on some channel.
Message posted on 06 Nov 2023 08:18 PM
Just started this evening. Watching a programme and it will suddenly disappear and the tv runs through a few channels and then lands on one at random. Then have to go back to original programme.
Better with recorded programmes but it still happens occasionally.
Message posted on 06 Nov 2023 08:21 PM
Re: The channels are changing on their own. Just randomly ending up on some channel.
Hi @CMarley
Make sure you have no Bluetooth devices in close proximity to your Q box.
Also check no buttons on the Q remote are sticking.
If they all seem Ok
Try completly resetting your Bluetooth remote.
